CPU Cooler Prolimatech Armageddon
8 Jan 2010
Just after a little advice please...
Im gonna get a 'Prolimatech Armageddon CPU Cooler' And would like to know if I should put '2 x Noctua NF-P14 FLX' on it or '2 x Noctua NF-F12 PWM'
(obviously with the 120mm Fan Clips) on it.
Or maybe one of each as I have seen suggested somewhere.
Thx any advice would be most welcome
PWM, most motherboards will be able to control it and make it run slower when the speed is not needed. Plus they're the newer versions of the Noctua's I think and they have more static pressure.
Noctua NF-P14 or Thermalright TY-140s. Or better yet, the True Spirit 140 which comes with a fan already. Only thing is, you have to check if it will fit in your case as it's 170mm tall.
