Hey, I have an i5-2500k running at stock on an ASRock Pro 3 Z68 mobo. I want to overclock it so need to buy my first aftermarket cooler. I do not want to spend a great deal. Basically I want to be able to OC my 2500k to a good frequency, but no higher than 4.5Ghz. I will not be doing a lot of stress testing or benchmarking or anything like that, I just want to get the most out of the CPU.
Budget is about £15-£25.
- Need to easily overclock to 4.5Ghz at low temps
- Ideally it will be quiet
- Ideally it will be easy to install
Options I have looked at (drawback that I perceive in brackets) are the Corsair A50 (noisy), hyper 212 plus (difficult to install and very large- I have a CM elite 430 case), and gelid tranquilo (expensive for my price bracket).
If anybody could recommend the best option or perhaps make other suggestions based on their own experience that would be much appreciated. Thanks!
