CPU cooler with NZXT HUSH case
5 Mar 2009
Manchester
I am thinking of upgrading my CPU cooler for my core i7 920. I am considering one of:
-Noctua NH-U12P SE 1366
-Thermalright Ultra-120 eXtreme 1366RT
-Coolermaster V8
-ASUS Triton 88
The thing is I don't know which one of these (if any) will fit in my NZXT Hush case, which is quite narrow.
Has anyone had any experience with this configuration ?
I have the hush, and I would be very surprised if any of those fit in it. When i measured it I figured that the Akasa 876 cooler at 138mm in height would have been a very tight fit. So anything more than that and I doubt it will fit.
I would say something like this would be your best bet - It's hard to find i7 coolers that will fit.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-015-ZA&groupid=701&catid=57&subcat=1395
WITH
http://www.overclockers.co.uk/showproduct.php?prodid=HS-040-ZA&groupid=701&catid=57&subcat=1395
Actually while searching the net I found a review of the case where the reviewer had a Cooling Silentator installed with no problem at all and its 153mm high. I guess that's something to look at.
my stepdad has a nzxt hush
with a thermalright cooler in it
so all the mentioned coolers will fit
