Current setup:
CPU: Ryzen 5800X3D
GPU: Reference 7800XT
Case: Be Quiet! Pure Base 500DX
Currently have 1x 140mm fan in the front intake, 1x140mm fan at the rear exhaust, and 1x140mm fan at the top exhaust
CPU cooler is an Alpenfohn Matterhorn
Looking to reduce noise levels of the CPU cooler, as it's the noisiest fan in my system, and does some annoying revving at times.
At the same time, it would be nice to drop the temps of my GPU if at all possible.
So, 2 options I'm looking at:
Arctic Liquid Freezer II 280mm, front mounted intake, moving the existing 140mm intake to the top exhaust
Noctua DH15 + additional 140mm intake in front of case + additional 140mm exhaust on top of case
I can't really find a consensus about which is the better option,
CPU: Ryzen 5800X3D
- With the AIO, the air coming into the case will be warmer, but there will be more space above the GPU for air circulation, rather than a heat source, and a huge heatsink right next to it blocking air flow.
- With the air cooler, there will be cool air entering the system, along with the fans on the CPU cooler possibly helping take the hot air away from the GPU, but also maybe reducing the amount of dissipation and concentrating the heat in that area of the system.
