CPU Cooling Help
Thermalright Silver Arrow.
If you're getting a big cooler then use low profile RAM. No fancy heat spreaders.
What are you using the PC for?
An i5 2500K is sufficient for most uses such as gaming.
An i7 2600K is better for things like video encoding.
Im going to be using this PC for both video editing and gaming, that is why im getting the i7. I'll be getting the Corsair XMS3 8gb that is quite low. Saw some reviews on the Thermalright and Im gna get that
