Mother Board: Gygabyte GA-P55-UD6
Proccessor: Intel i5-75 - Socket LGA 1156 - 2.66 GHz - 8MB Cache - PCG 09B - 4Core
RAM 4GB (3.25 usable)
Cooler Master Case
Windows XP & Windows 7 Dual boot.
At present I am using the stock CPU fan.
Running at the default 2.66 for the moment to try and keep temp’s down.
Temp’s whilst sitting idle is in the region of 51 – 53 degrees (each core) which in my opinion is a wee bit on the hot side so I am looking for a decent fan for this. It must be quiet\silent whilst in operation.
AS I do video editing amongst other intensive uses, the temp’s can shoot up quite a bit so looking for a couple of recommendations for CPU fans.
I was thinking of something like the following, but will be guided by the experts
Akasa AK-CC4005SP01 Venom Nano CPU Cooler
(Socket LGA775/LGA1156/LGA1366/AM2/AM3)
Or
Cooler Master Hyper 212 Plus (Socket AM2/AM2+/AM3/775/1156/1366)
Finally what would you say is a safe running temperature for my processor?
ErnieK
Cooler Master Case
Or
ErnieK
I use an Asus board here, so no idea if your Gigabyte board allows that.
