I'm about to embark on my first water cooling project, and can't wait!
I have a question about the best way to do it though. The components in the loop will be an FX60, an X1900XT and an X1900XT-X. I've decided to use Swiftech's new Apex kit (Apogee block) and two of their MCW60 gpu blocks.
The question is, should i hook them up to be CPU-GPU-GPU, or use 'Y' splitters to keep the GPU blocks on a separate line as it were. Er... something like this:
xxxxxxxxxx-----CPU------
Pump---<xxxxxxxxxxxxxxxx>---Rad
xxxxxxxxxx--GPU---GPU--
(sorry about all the 'x's, just pretend they're not there. Tried using spaces but the form took them all out and left justified everything)
Anybody got any advice?
Thanks!
Thanks!
