Cpu extreme high temp :( i9 9900k
What case fan setup do you have? H510i stock fan setup gives horrible case airflow, but if you remove all PCie back slot covers to increase rear vent area around GPU, put a couple of good 140mm front intakes in and block all openings in fan mounting panel not covered by fans it is pretty good. 2x good pressure rated front intakes are all the case fans needed with PCIe back slot covers removed. ;)
You might find link below is to basic guide of how airflow works and how to optimize case airflow helpful.
https://forums.overclockers.co.uk/t...-i-put-my-temp-sensor.18564223/#post-26159770
