Hi, my system seems stable and i'm not to be having any problems but my cpu keeps failing super pi 1M when at stock speed/voltage. Most of the time it will pass the test fine without errors but the odd time it will get a 'NOT EXACT IN ROUND' error.
Today I overclocked the cpu to 2.4ghz and ran super pi again and it gets a few different errors on every run, even before the initial value has been calculated but every other application was stable.
I've ran Prime95 for 6 hours (when at stock speed) and I also run folding@home constant and their both not getting any errors. It also ran memtest for 1 hour without errors.
So i'm not sure why my cpu is failing super pi but everything else is fine.
Does this mean my cpu is starting to break?
Is there anything else that could be causing the errors?
Spec is in my sig
Thanks
Spec is in my sig
Thanks
