Hiya there everyone.
I have just been given computer and wish to make it work just for internet and email etc..
the specs are:
MESH
AMD K7 Processor
AMD Athalon(TM) XP1800+
1.54GHz
512mb of RAM
CD-RW
DVD-Rom
Zip Drive
(I do not know how to find out what socket this cpu is, I am kinda at a loss for what to try next if you cannot tell)
I ran an application to see if I could find out more information regarding the mobo but it didn't identify it and there is no writing on the mobo it's self.
The problem is that I have the computer working with XP Professional and all is well, then about 2 minutes into switching it on the CPU fan makes an awful racket, if I touch the CPU in the middle and stop it spinning it stops making a noise slows down then speeds up a few minutes later it all happens again.
Is there a way I can replace just the fan, or do I have to replace both the fan and the heatsink, and if so is this easy to do?
I apprieciate that you expect people who have problems to do as much research before coming to you, I hope you can see I have done all I can without some more advice.
Thanks for your time
Switch
the specs are:
MESH
AMD K7 Processor
1.54GHz
512mb of RAM
CD-RW
DVD-Rom
Zip Drive
Switch
