Hi,
I just flashed from 1305 to 1407 (Asus P5W DH), and now my CPU fan is always at max 3350rpm and very noisy. Prioir to this upgrade my PC was practically silent, even with side panel removed to assist cooling with CPU Fan @ 1800rpm. CPU temps have dropped by 5 Deg now which is all well and good but I would prefer the extra heat and silence.
Has anyone else experienced this with 1407? And how did you resolve this? If in deed you did resolve.
I could revert to BIOS 1305 not a problem.
Or are there any decent fan control programs out there that actually know what they are doing and produce accurate readings. I'm not endeared to speedfan, I have used this in the past on several boards and it seems to me it just has wild guesses instead of actually reading the correct values from the monitoring chip(s)
I have tried as many possibilities in the power section of BIOS as I could, but they seem to have no effect at all. Except AI Quiet, which when enabled locks CPU volts at auto and enables EIST and C1E.
Any help would be greatly appreciated.
/EDIT: 100th post, I best oil my tommy gun and fix the quick release catch on my violin case
