Hi all,
I have an Asus ROG Maximus VII Ranger motherboard and a Corsair H80i GT cooler. Everything is working fine but I have a question about connecting to the fan headers.
The instructions to the H80iGT say that I have to connect the pump power cable to the CPU_FAN header on the motherboard and connect the fans that are attached to the radiator to the two connectors coming off the pump. This I have done.
However, if I don't connect anything to the CPU_OPT header I get a CPU FAN error when booting. If I connect the cooler to the CPU_OPT header instead of the CPU_FAN I get the same error.
I have to have something connected to both of the headers. To get over this I have connected a case fan to the empty header.
Everything is working fine, the machine is rock solid and the fans only spin up when the machine is under load. I'm getting a CPU temp of 34c when the machine is idle and I've not seen it go above 65c-ish when under load.
I don't see it as a problem but I'm just curious, why do I have to have both headers connected?
Thanks
Thanks
