CPU fan detection bios error on pc startup
23 Oct 2008
Yesterday I got error about the cpu fan so I’ve set it to ignore for now in the bios so I can at least get the pc to load into windows, I noticed like a day or two before when I was playing around in the bios(well loaded into it to check the version as I was looking to update it) that it had n/a next to the cpu fan speed but can’t remember if that’s always been the case. I have the NZXT Kraken Z63 AIO not an air cooler, never had that error in the just under 3 years I’ve had the pc.
P.s wasn’t sure which section to put this question under
Iirc the nzxt aios have like a specific thing coming off the loom thats just to go on the cpu fan connector just for that. But maybe thats not plugged in? But other than it telling the bios theres a cpu fan plugged in it doesn't do anything and everything else is controlled by the various bits that come with the aio.
Might just be you switched it off before and don't remember, and the bios reset when you updated, I guess
The error happened before I ran the bios update, I’m sure I plugged in everything on the motherboard like it said but going to check it when I get the chance. While I have it open how do I check if the pump is failing?
Forget to mention it’s the Asus Strix B650E-E Gaming WiFi motherboard, the bios was at 1616(update back in May 2023) before I updated it to the latest(3602).
