CPU Fan Error! Help?
11 Sep 2008
Northern Ireland
so woke up this morning, all of a sudden, when booting up my PC goes to this new screen, showing the AMI symbol at the top, and it comes up "CPU Fan Error, press F1 to continue".
So I looked into this and people always said just disable the warning in the BIOS. But I want to know; whats wrong with the Fan (why is it suddenly playing up), how can I fix the problem with the Fan (not by disabling the error in the BIOS, i want the problem actually fixed), and is the fan still working as it should?
thanks in advance
Q6600 at stock
4870x2
4GB RAM
Z600 CPU fan
Asus P5Q delux
have you got the latest BIOS? I'd imagine if its a known fault they'd of fixed with a BIOS release, if you dont have latest try flashing your BIOS and see if that gets rid of it
your the only person that can tell us if the fan is working, have a look inside the case if its not working youll get random restarts etc also try updating the bios or disabling the error.
it seems working, temperatures are as they are always, but why would it say there is an error when I can see the fan is working (for the moment anyway :p )
Hey petemyster,
this is quite normal when using 3rd party heatsinks featuring 92mm/120mm fans while using BIOS controlled fan speed reduction.
The BIOS is tuned to flag a fan error if the rpms fall below a certain speed (800rpm approx). The problem is that the larger the fan the slower it normally spins and when using BIOS speed reduction the fans motor will not always reach the BIOS's target preset rpm.
If you leave the detection enabled you will find that sometimes it boots right up while other times the motor gets a bit lazy and the alarm is tripped.
The only thing you can do is:
  • Disable the RPM sensor in BIOS
  • or Disable Q-Fan
  • or Change to a smaller fan with naturally higher rpms
It's not a big problem so don't worry too much! :cool:
Hey petemyster,
  • or Disable Q-Fan
ok, thanks for the explanation.
thanks everyone :D
