I keep getting this CPU Fan as failed message on startup, if I go into the Bios, I can see that the fan speed is extremely low(300 RPM), but has soon as I start up Windows and check with Asus Prob it is back to normal speeds(1900 RPM)...
Could it be that the fan has dust on the inner mechanism and takes a little while to kick in? Faulty fan? BIOS gone a little weired?
Any suggestions on how best I check the fan?
Cheers
S!ap
PS using a Freezer Pro and have cool and quite turned off in BIOS
Cheers
S!ap
