For the last 2 months, every time i boot up my pc it gives me an error message saying that the CPU fan isnt working, which takes me to the bios, and i just have to exit. Then it goes into windows as normal.
Looking at the fan, its still running. Ive cleaned the case up from dust to be safe. Ive downloaded cpu temp and hardware monitor, both seem to suggest the temp is ok i think.
Anything else i should be doing to try and fix this?
