CPU Fail warning. Message appears at random times maybe once or twice a
week.
When this happens sometimes you get a chance to say ignore and it will carry on working till you switch off.
Other times it just freezes. Reset and all is well ...went to the BIOS to
check temperature but at 40C nothing to worry about.
Why do I get a message when at the BIOS I have CPU Fail warning turned = off?
Have swapped CPU stock cooler with Arctic Cooler v7 rev 2
Also swapped 750W PSU with a brand new 850W.
Not using that much power to be honest.
Have removed all Gigabyte utiolities in case they were causing issues (ET6, Easy Energy Saver)
I have now turned off all FAN warnings including CoolNQuiet at the Bios but
the issue remains.
Also turned the Core voltage down from 1.35V to 1.25V ...same problem.
Have turned off all scrensavers and power saving utilities at the OS.
Nothing much in event viewer ...
Hardware Monitor looks OK too
Any ideas would be welcome.
There is a new Beta Bios for this Mobo but that is mainly to allow x6 Core
Anyone had similar issues ?
Cheers
Frank
MoBo GiGaByte MA790XT-UD4P
AMD 955 Quad Core 3.2Ghz 8G Ram W7 64 Bit , MS Office 2010
DVB-S (AzureWave AD-SP400)...Cooler=Arctic Cooling Freezer 7 Pro Rev2 Quiet CPU Cooler.
Monitor=ZR24w
week.
the issue remains.
Cheers
Frank
Monitor=ZR24w
