CPU Fan Failure Warning.
31 Jul 2007
Manchester
Hi all, Anyone had this problem, i have an Asus M3A32-MVP Motherboard, Just installed With a AMD 6000+ Dual Core, and for some strange reason i get a CPU fan failure message at post, Yet i know that the CPU fan is working fine, can anyone help please? Thanks.
You should be able to disable the warning in the BIOS.
Are you sure that you've connected the CPU fan to the CPU fan header?
Could be the fan running slower than the bios is expecting or the temp is hotter than is set in bios?
