CPU fan for x2 4600+ ?
6 Jan 2007
Ok got my new chip - very quick! but im still using my stock AMD 3000+ fan, any ideas of what could replace it ? idealy something that uses the stock mounts ? i did purchase a Zalman FS-C77 but its so large and heavy - also have to remove mobo to fit it - so its going back , any recommendations ? or can i stick with the stock fan ?
yup that one looks very good - ive not had any problems with the normal amd 3000 fan for the last couple of days - but do worry its not up to the job - is there any windows software i can use to check the temp of it ? if not that fan looks spot on thanks !
There is normally a program that comes on the mobo CD. Any of the following will do though:
MBM5 - if it's supported or if you can find a confi file on the net for your particular board
SpeedFan
Everest Home Edition - the free one
The Freezer64 isn't the best cooler about, but it's easy to fit, if you really need that (just how often do you take them in and out :confused:!) and it's very good for the money.
thing is i dont want to take the mobo out to fit a non standard socket one... to be honest seems to be running ok on the standard cpu fan - will have to monitor temperate to see.
i've got a Arctic Cooling Freezer 64 Pro for my 4000+, and my bro has one on his x2 4200+.
I would highly recommended it!
