CPU: Fan Heatsink vs WaterCooled
16 Mar 2014
Hi all,
I wanted to get some opinions on the below 2 products.
I think the Below fan heatsink is good value for money - decent airflow for the cost and noise.
However I would like to get great cooling without over doing the weight, size and airflow within the case and feel that maybe the all in one cpu cooler would be a good choice.
Products:
YOUR BASKET
1 x Corsair Hydro H60 V2 High Performance Liquid CPU Cooler £49.99
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
For 2.5x the cost is the performance of the all in one liquid cooler better?
I don't want to spend lots of money on the cooler...
Cheers
If budget is a concern the air cooler is a no-brainer. The weight won't be an issue if mounted correctly. Check this link out for comparisons between AIO and air coolers. The upshot is unless you go for one of the better AIO units, the extra outlay is rarely worth it.
