So I've recently finished my new rig and went from full-atx to mini-itx. The only concern I have with my build is that the fan of my Noctua NH-U12S CPU cooler does not have enough clearance from my corsair 2x16GB RAM on the motherboard. If I try to install the fan as an intake, it pushes the RAM to the side by an uncomfortable amount.
Due to this, I set the CPU fan as an exhaust to the back side of the cooler. However, it is very close to the back exhaust fan of the case. Not touching or anything, but they run at different RPMs. The CPU fan based on temps (560-900RPMs), and the back case fan is connected to the AIO pump connector and thus runs at 1400RPMs continuously.
My case is an NZXT H210 and the fan setup is 2 front intakes, 1 exhaust at the back and one exhaust at the top, with the CPU fan in exhaust mode blowing directly on the back case fan. Peak stress temps reach 74 degrees and idle 32, but I am still a bit concerned if I should switch to an AIO, or if an exhaust CPU fan so close to the case back exhaust fan is still suitable for cooling and I should leave the system as is.
Thanks for any advice.
