CPU Fan into the MB or Fanmate
18 Feb 2006
Halifax
Hi
I am using the Zalman CNPS9700-LED CPU Cooler to cool my C2D E6850
I am using the Zalman Fanmate2 fan speed controller to control the speed of the fan on the cooler, I use headphones when gamng so I can not hear the case fans, would I be better to plug the CPU cooler into the motherboard header. Would the fan then throttle to a higher speed when more demand was placed on the CPU.
Current temps - Minimum speed setting for the fan
CPU 29 °C (84 °F)
If the fan is of the PWM type i.e 4 PINS it should if setup correctly in the bios sort it for you :)
If not then the fanmate is fine just dont turn it down to low so that the CPU does not get cooled properly.
DeadMan
