Permabanned
- 6 Feb 2009
Hi guys
Am really confused here.
I just got some new kit delivered, Gigabyte 7ZZ-UD5H mobo with i7 3770k CPU.
I also bought an Artic Freezer i30 with it.
The fan is connected but it doesn't seem to be spinning. Or, sometimes it does and sometimes it doesn't
When sat in BIOS it doesn't spin, unlesss I give the fan a push and then it will start spinning.
It booted into Windows and I pottered around a little bit, nothing intensive - when I loaded speed fan, the fan was NOT spinning, but the core temps were reported as between 18-20oC
in BIOS, the CPU temp is reported as 38-40oC
Is the fan faulty or is it not spinning because it doesn't need to to keep the CPU cool?
Any advice appreciated.
