i have a xenomorph gaming system which i bought in dec2011 with a asus P8H61-M motherbaord. a little while ago the CPU fan no longer worked and i had the fan replaced by overclockers with no fuss, now the other day i start to get the message that the CPU is at 0 RPM in AI suiteII. i opened tha side of the case and the fan is still working and keeping the CPU cool, i read on the net that if the threshold is set at 600 it's too low for AI suite to read so it will just register at 0 RPM's. but there has been no issues before with AI suite eading the fan at 600 threshold, so i set the threshold higher to 1000 but still it shows at 0 RPM's. i run a fan test and it's looks ok apart from 20% which shows 0 RPM's, sometimes the fan will register at around 850 RPM's but then just drop straight to 0 RPM's again. i just need some good advice as this is my first PC and i am very happy with the product and overclockers, does it sound like there is a porblem with the motherbaord?.
sorry for the long line of text but just wanted to get as much info as possible.................sudeki300
