Hi guys, I have a system including:
Gigabyte GA-P55M-UD2 Intel P55 (Socket 1156) DDR3 Motherboard
Zalman CNPS10X-Quiet CPU Cooler (754/939/940/AM2/AM2+/AM3/775/1156/1366)
and I'm having a bit of trouble getting the motherboard to control the speed of my CPU fan. When the fan is installed without the Zalman fanmate, the fan simply spins at 100% speed all the time. The fan is a 3-pin conenctor on a 4-pin motherbaord. I have tried enabling motherboard CPU control in the BIOS but to the same effect. Am I right in thinking that I need to buy a 4-pin fan for the motherboard to be able to adjust the speed itself? If so which kind should I go for, are case fans different to CPU fans?
Would something like this do:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-010-SY
My system is not overclocked, temps are around 30c idle, but I would like the motherboard to control the speed when I play games etc, as at the moment I'm not really sure how much to turn up the fanmate.
Many thanks, sorry if it seems a stupid question but this is my first build and it's bugging me a bit!
Al
Al
