CPU Fan Speed error - Maximus IX Formula
30 Jul 2007
Surrey
Hi guys,
Set up my new system and pressed the power button for the first time and posts no issue. However it wont go past post due to:
"CPU Fan speed error detected."
It suggests adjusting or disabling the Fan Speed Low Limit in BIOS which I think I have done:
In BIOS under 'Monitor' tab and 'Q-Fan Configuration' i have set the:
"Cpu Fan Speed Lower Limit" setting to Ignore.
However I am still getting the same error.
My H100i GTX is plugged into the CPU Fan header. Both fans are spinning, the corsair logo is lit and i can feel water moving in the pipes. Bios is showing a temp of 30degrees too.
Specs:
I7 7700k at stock
Asus Maximus IX Formula
16gb DDR4 3200mhz RAM
Corsair H100i GTX AIO
