My PC includes the following:
Motherboard - MSI P67A-C45 B3 Intel P67
CPU Cooler - Scythe Shuriken Rev. B
I cannot adjust the CPU fan speed. According to both SpeedFan and CPUID Hardware Monitor, the fan sticks at 830 rpm under all conditions. Whilst this is relatively quiet, I'd like it to work harder when necessary and switch itself off altogether when not required.
The fan's speed range is 650-2200 rpm and it is PWM, according to the official blurb - http://www.scythe-eu.com/en/products/cpu-cooler/shuriken-rev-b.html
Within the BIOS, I have an option to use smart fan speed - I've tried every sensible setting without success.
I've set up a SpeedFan profile, again with no success (the case fan changes, the CPU fan will not).
The only thing I can think of is that I'm being daft and the fan simply won't switch off entirely. This doesn't explain why I can't get it to run faster!
To be clear, the CPU fan is plugged into the correct 4-pin header on the motherboard.
Any thoughts?
Thanks in advance.
Any thoughts?
Thanks in advance.
