CPU Fan spins for 1 sec then goes off
20 May 2004
I have just assembled a machine and turned it on. The CPU fan spins for 1 sec and then stops, no display on the monitor and no lights on keyboard and no POST beeps.
Any idea what could be wrong?
Check all cables are in properally and take out any add-on cards you have in (Graphics, sound cards) and then see what happens.
Could you list your full specs.
Double check memory are in the correct slots and also try a CMOS reset.
Hi Guys, thanks for coming back to me so quickly.
The CPU power connector is a 4 pin. Which is connected.
All the cables are inserted correctly and memory is in correct slot. I have also reset the CMOS.
Spec is:
MB: Veracruz 945G-M4 Rev B with onboard graphics & sound
Intel Skt 775 Dual Core 3.06Ghz
1Gb DDR2 PC2 5300 DIMM
Standard Sata HDD.
Have you checked the power and reset switches are conntected properly? You can also try removing all the front panel stuff and starting it by touching the two pins with a screwdriver instead.
