cpu fan splitter question
so with the molex version, along with connecting to the psu via the molex connecter, do i also connect the motherboard connecter to the cpu fan socket?
Yes, power from the molex helps for two or more fans, but the fan speed is controlled from the motherboard header as normal.
EDIT Check if new cooler comes with a splitter, my Phanteks did.
