Hi guys
I have an issue with my CPU fan. It stops spinning while gaming. It doesn't happen all the time.
If I reboot the PC, fan starts spinning. I have this PC for over a year and never had this problem.
No component is overclocked.
Mobo: Asus PRIME x470-Pro with BIOS 5220 - 11.09.2019 - Wraith Prism cooler
CPU: Ryzen 2700x
RAM: 2 x 8 GB HyperX Fury 2666 Mhz
PSU: EVGA SuperNova G2 750W
GPU: Sapphire 5700x Nitro
Today I noticed that when the CPU fan stopped, 3 other case fans stopped as well. The other 2 are working fine.
Another thing worth mentioning, while the PC was running, I re-plugged the power cable for the CPU fan, it starts spinning for 2 seconds then stops. After that I plugged it the other way with only 3 pins and it started spinning normally.
Not really sure what's causing this. Any ideas?
Cheers!
CPU: Ryzen 2700x
Cheers!
