lee786
lee786
my cpu fan is really starting to annoy me
my pc room gets quite warm
this time of year so my temps go up a small bit at the moment my pc is doing nothing and i have temps from core temp of
core1: 47
core2: 42
core3: 42
core4: 46
i wouldnt say these are high temps for a "go q6600" are they ?
soon as the temp gets any higher than this the cpu fan starts to make a high pitch hum this is whats driving me mad lol wouldnt mind so much but it cost me £30 the cpu fan Zalman CNPS9500A-LED
btw i do have 2 80mm Noctua case fans and my pc one blowing in cooling hard drives the the blowing out the back of the case.
other than the huming sound coming from the cpu fan i would be happy
so i think im going to try and upgrade the fan
im looking at the Noctua NH-U12P cooler do you think this would be an upgrade that would solve my noise problem ?
would it even fit on my gigabyte ds3p v1.1
my pc room gets quite warm this time of year so my temps go up a small bit at the moment my pc is doing nothing and i have temps from core temp of
core1: 47
core2: 42
core3: 42
core4: 46
