CPU fan via a fan controller ?
7 Nov 2002
pantyhose factory
I have got my hands on an aerocool fan controller and I wanted to route the CPU rad fan via this to control its speed.
is this possible because I always though if there was no fan plugged intot he CPU fan header on the motherboard that you couldn't post or you would get a post error and the machine may not boot up ?
I remember having issues back in the old days when i tried this using a KT7A motherboard. The board I have got now is a MSI P67A-GD65 Intel P67 (socket 1155) Sandy bridge
The Cooler I am using is the Corsair H50 so the pump will still be connected to a header on the mobo but I want to put the fan pluged into the fan controller
You won't get a POST error. Might have 'CPU fan error, F1 to continue' but you can disable that notification in bios.
Run a yellow wire from the fan to the CPU header and the remaining red and black wires to the controller. May involve a little bit of soldering and having a spare fan connector.
