just testing new rig ...havent put in case yet as I will be doing a WC system for the CPU, just using stock cpu cooler that comes with i5, reading 93degrees...which cant be right...can it ?
Check all the push pins are securley pushed through or refit completely if your temps don't change.
Ideally when fitting push pin coolers - push down on two diagonally opposite pins at the same time to ensure you get an even fitting? If you can't manage this do one at a time but again press down the pin diagonally opposite the first pin you secure.
