With the NHD-15 or Deepcool Assassin 3 air coolers the fans have to be moved up about 10 to 15mm to clear the ram. Will putting them both in a pull configuration be ok? The case that I really want has really good cooling u using 3 120mm fans blowing onto the components inside. I may buy some krynaught paste for the CPU anyway.
Thanks though.
