CPU for gaming/VMware workstation
30 Sep 2015
Hi,
I'm looking to build a computer for gaming (1440p) and lab work (VMware - multiple DC's and Exchange servers). I'm toying with the below and am torn between the CPU's 5820k, 5930k, 6800k and 6850k (not willing to consider 6900k/6950k as they seem to be be incredible expensive). Trying to get as many logical processors as possible without spending silly amounts of cash.
Intel Core i7-6850K 3.6GHz 6-Core Processor
Corsair H110 CFM Liquid CPU Cooler
MSI X99A SLI KRAIT EDITION ATX LGA2011-3 Motherboard
G.Skill TridentZ Series 64GB (4 x 16GB) DDR4-3200 Memory
Samsung 850 EVO-Series 500GB 2.5" Solid State Drive
Samsung 950 PRO 512GB M.2-2280 Solid State Drive
Zotac GeForce GTX 1080 8GB AMP! Extreme Video Card
Phanteks Enthoo Evolv ATX Glass ATX Mid Tower Case
EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Asus PG279Q ROG Swift 27.0" 165Hz Monitor
Would anyone have any recommendations on the CPU selection?
I'd go for the 6800k. It has higher IPC than the 5820k, which should help with your VMs.
No point in getting the more expensive 6-cores as they only have more PCI lanes, and you don't need those unless you're getting 2 GPUs. And with the state of SLI/Xfire support, I think people who get 2 GPUs are brave.
for under £350 form the bay I got dual hex core xeon 5650, dell t5500 workstation with 72GB of ram - (65 2x cpus, £110 72 gb ram, 130 for the t5500) - you need to add storage (and a sata 3 card but mine was so fast I never bothered keep meaning to though).. you can have a dedicated esxi monster host.. you can probably crank down your game PC spec slightly end up spending the same money..
Just a though..
^ I like this idea in principle but the 5650 is Westmere EP, they're pretty old (6.5 years) chips.
Slower arch, 700-1000 MHz lower clock speed than the CPUs OP is considering, higher power consumption, no AVX instructions, no DDR4. (ECC though which is nice.)
Yeah to be honest I wouldn't be surprised if the 6800k was actually the same performance in an unlimited-thread scenario. And it should be over 2x the performance in single-threaded scenarios.
