cpu Frequency setting in bios??
5 Jun 2005
Southampton
My bios has a lot of ‘auto settings’ and i’m having to check and change some due to vista not installing. What should the cpu Frequency be set to for an AMD x2 5000+ chips?
just want stock speed at the mo, until i get over this issue of vista not installing. however this chip comes unlocked acording to ocuk, so is that you change? when cranking it up?
you can do but you can also change your multiplier if you have th eblack edition of the 5000.
stock speed is 200mhz (cpu frequency) x 13 (cpu multiplier) = 2.6ghz
you can change either to overclock but you will need to have a play and see what works best.
