Hi,
Recently put together my first build and starting to see some hiccups. Hoping for some advice.
Essentially, my screen either goes grey with horizontal white lines, or totally black. Computer is still on and music still plays. This usually happens when I'm gaming and is pretty sporadic. I've started running MSI afterburner to check temp/fps in game. The most intensive game I play is Skyrim, modded; I'm on av. 60fps and hovering around 57degrees. I've had issue though even when playing FM2006!!
CPU: G3258 @ 4.3ghz
GPU: MSI R9 270x OC (Factory OC)
PSU: Corsair CX600w
RAM: 8gb
Have plenty of cooling, CPU never goes above 60degrees. Bit confused over what could be causing this. Any and all help appreciated!
Ned.
CPU: G3258 @ 4.3ghz
PSU: Corsair CX600w
RAM: 8gb
Ned.
