how do you guys calculate this? how do you know if a cpu will under perform the gpu etc? is there a specific method?
obviously you don't stick a 1.4ghz single core with a 5870 for obvious reasons but how do you calculate the right mixture?
is the calculation done by the number of cores e.g. single, duo, quad etc etc or is it based on the speed?
i have not noticed any difference in the last 2 cpu's with the same card.
i had a Core2Duo @ 3.8ghz with 4890 asus (pretty much same FPS in games)
also Core2Quad @ 3ghz with 4890 asus (same fps -ish give or take a few fps)
