cpu/gpu on 1 360 rad
21 Apr 2012
hello everybody ,
currently i have
black ice GT xtreme lite 360 rad,
3 kaze jyuni 1900rpm fans hooked upto a fan controller
a D5 pump , cooling my 3570k.
just about to order a waterblock for my 7950,
would the above be suitable to keep it all cool ? cpu & gpu
its only temporary solution (maybe month or two) till i can add another 240 rad into the loop.
Will be perfectly fine, adding the 240 to that would only be an optional extra not a requirement. A GTX lite 360 will easily cool an i5 plus a HD7950 and have room for over-clocking.
Older Nehalem i7 @4Ghz and 7970 @ 1200/ 1600 on a single thin 360 rad and temps are fine.
I am considering changing it to a thicker rad and am adding another thin 240 rad as going to crossfire my 7970's and want to run fans at as low a speed as possible.
You will be fine on a 360 and adding a 240 with those components would be overkill imo, but I suppose the saying is you can never have enough rad.
