CPU & GPU Temps
17 Nov 2011
I've replaced the Cooler Master CM12V cooler with the Scythe Big Shuriken 2 but CPU and GPU temps seems to be the same, this is my BIOS CPU and system fan settings,
Temps are monitored using Open Hardware Monitor,
Cooler Master CM12V
CPU Max - 30°C
GPU Max - 70°C (Fanless)
Fan RPM Max - 2300RPM
CPU Max - 30°C
Fan RPM Max - 1500RPM
More info needed....30c max temp seems very good for any cpu :)
Try using core temp or real temp to measure temps and gpu-z for gpu
What stress testing program are you using for cpu and cpu?
CPU and GPU temps are load temps from 1-2 hours of playing 720/1080p MKV movies and I haven't stress test the system
I've compared CoreTemp and GPU-Z temps to Open Hardware Monitor and it's the same
CPU is AMD Phenom II X2 545 and GPU is Asus ATi Radeon 6450 (Fanless)
