Hawklord said:With my X2 4200+ overclocked to 2.75GHz I'm getting 38 idle and 52 deg under 100% load in these warm times Only recently installed it so not sure what the temps would be @stock with normal UK temps but it does seem to do the job admirably with no fan
james.miller said:the scythe ninja plus comes WITH a fan. it is also only of any use without a fan for bottom end cpu's. you cant run a modern cpu fanless
e36Adz said:I get higher temps then that WITH a fan in this hot weather! :/
Are you using the Scythe Ninja Plus Heatpipe CPU Cooler, because im looking for something to quieten my PC down abit, might get this if it can do the job
james.miller said:no it isnt, unless you count having a case fan so close to the cpu sink that you can class it as 'passive'
