Morning,
After buying myself a AMD Athlon San Diego 3700+, i decided to install the processor yesterday after i was told i didnt need to do anything other than take the old one out and put this one in. Now my old processor was a Winchester 3200+ running on the Asus A8V Deluxe absolutely fine, took it out put this one in an drebooted to get this message:
*****UNKNOWN PROCESSOR REVISION*****
The processor installed in your system are of unknown revision, please contact your bios vendor for appropriate updates.
FATAL ERROR, SYSTEM HALTED
So how am i going to get round this i thought, so i reset the bios and still the same error. Is is a bios update and if so how do i do it please? i cannot get into the bios or nothing?
Please help......
Regards,
Kris
Please help......
Regards,
Kris
