My PC has always ran a little on the hot side but its getting much worse.
6 to 8 months ago it ran at 45 idle to 66c full load perhaps 70c when my room was hot day mostly 1000 to 3500 RPM winter time. Now it’s on 70 idle 3500 to 4500 RPM and 95c full load with small amounts of throttling at 95c. Sometimes it hits 110c with lot of throttling and soon after shuts down but that’s rare.
Sometimes like last night it hit 4200 to 4500RPM at 70 idle to make matters worse that was undercloaked from 3.2 ghz down to 2.8ghz with the Vcore lowered from the default 1.4 down to 1.235. Even taken into account its summer and warmer those temps seem way too high.
Clearly the 110c temp is impossible and I have known since early on that my temp sensors are off perhaps by as much as 20c. I figured as throttling starts at 95c then the real temp is closer to 80. Oddly sometimes it hits 97c without throttling.
As I don’t move the PC and it’s a good 8 months old now I don’t have much idea on what’s wrong. Do temp sensors change over time? Is it possible that the temp is the same as 8 months ago only the temp sensory has got worse?
Do heat syncs get unseated even if the PC doesn’t move? It feels secure but I haven’t tried re seating it yet. Got an ArctiClean Thermal Material Remover + Arctic Cooling Freezer 7 Pro and 2nd case fan on order and will try that over the stock fan next week. EDIT: the heatsync feels very hot to the touch, cannot keep my fingers on it. But it does not burn me.
What about the thermal material can that die and need replacing after such a short amount of time?
Anyone got other ideas on what could be causing the temp increase?
PC is a Asus P5WD2 motherboard with a dual core 3.2ghz Intel CPU.
