7 Jul 2006 at 18:52 #1 joffy joffy Associate Joined 18 Oct 2002 Posts 1,364 Location UK Anyone recommend using a CPU holder like these? Would it help with vibration? Last edited: 7 Jul 2006
7 Jul 2006 at 18:53 #2 benjo benjo Soldato Joined 4 Sep 2005 Posts 12,829 Location London You mean a case holder? I doubt it would stop vibrating because its the parts inside that resonate, so the sound would still be there
7 Jul 2006 at 18:58 #3 Yewen Yewen Soldato Joined 9 Nov 2003 Posts 17,700 Location Leeds Waste of time, I bought two and made one for my GCSE Systems project and fitted an alarm to my copy. Does nothing worth while but allows you to wheel your case about.
7 Jul 2006 at 18:58 #4 joffy joffy Associate OP Joined 18 Oct 2002 Posts 1,364 Location UK Yeah I guess so, but it be worth using one just to lift case off the floor I guess.
7 Jul 2006 at 19:01 #5 Yewen Yewen Soldato Joined 9 Nov 2003 Posts 17,700 Location Leeds Much better off replacing your feet with some castors. http://www.rosshandling.co.uk/castors.asp
7 Jul 2006 at 19:04 #6 KizZ KizZ Soldato Joined 18 Aug 2005 Posts 5,236 Location Lincoln A CPU is not the computer!
7 Jul 2006 at 19:07 #7 joffy joffy Associate OP Joined 18 Oct 2002 Posts 1,364 Location UK KizZ said: A CPU is not the computer! Click to expand... Stockists call them CPU holders/stands
7 Jul 2006 at 19:07 #8 Yewen Yewen Soldato Joined 9 Nov 2003 Posts 17,700 Location Leeds KizZ said: A CPU is not the computer! Click to expand... No but that is what they are called. EDIT: Joffy beat me to it by literally 1 second!
7 Jul 2006 at 19:09 #9 KizZ KizZ Soldato Joined 18 Aug 2005 Posts 5,236 Location Lincoln joffy said: Stockists call them CPU holders/stands Click to expand... OK. That's odd
7 Jul 2006 at 19:11 #10 Yewen Yewen Soldato Joined 9 Nov 2003 Posts 17,700 Location Leeds KizZ said: OK. That's odd Click to expand... Not really, makes more sense to your average consumer, especially for products such as this; correct or not. On this note a computer case is actually a system enclosure.
11 Jul 2006 at 12:10 #11 joffy joffy Associate OP Joined 18 Oct 2002 Posts 1,364 Location UK Well I just got the holder in the 2nd pic above and MY CASE IS MUCH QUIETER! Also before you could hear the pc in the room below vibrating through the floor, now absolutely silent!
