Permabanned
- 15 Jan 2006
My CPU and system is running quite hot in this weather so I reckon I am going to buy some stuff to sort it out. Not to mention that the retail cooler is annoyingly loud.
Currently got 1 120mm fan in my case and the retail cooler on my Dual Core 3800.
Thinking of buying 2 120mm Akasa Amber fans (case allows you to put an additional one in to cool hard drives) and a Arctic Cooling Freezer 64 Pro.
I'd also need some thermal paste though but I am not sure which is best? The Arctic Ceramique Thermal Compound is out of stock, is the Artic Silver 5 any good?
And also what will I need to clean the remains of the pad (I think the retail cooler comes with a pad on the bottom right?) from the cpu and the bottom of the heatsink? And is the procedure for removing the remains on the CPU exactly the same for the cooler? Thanks.
