I've discovered that my E6300 is concave! So I guess I need to lap it. I have a few questions about it, for anyone who has experience with lapping.. If you can advise me with any of this then please do
Right, this is a paint drawing of my problem
The gap, in reality, is really small. But I guess it's enough to make a big difference - my heatsink's base is at least 15'c cooler than the core temp - sometimes even 25'c cooler, so this would explain why! I would only expect a 5'c, MAYBE 10'c, difference between the core and the heatsink.
Would you agree that this is my problem? I idle at 57'c where others are idling at 35'c on the same processor.
Can you give me advice on lapping?
Is it worth lapping and voiding the warranty?
From what I've read, you get a little bit of oil and drop it onto each piece of sandpaper you use. First, you use 400 grain, then 800 grain, then 1500 grain, then 2000 grain. When doing it, you put the processor IHS-down onto the sandpaper, which should be on a pane of glass. Then you move the processor in small circles applying gentle force.
How long should I do it on each size grain sandpaper? I guess longer with the 2000 than the 400?
Thanks for any advice or warnings
