Hi guys
Spec in sig.
Thinking about an upgrade and pondering between a 3700 A64 or X1800xt. so i thought i would run the far cry benchmark at 1024 and 640 res max settings. I found that both averaged 60fps +- 0.6. This is with vsync disabled, so am i reading this correctly and am cpu limited? And therefore better off getting the 3700 rather than gfx, or both. Obviously being used for gaming
Ps only able to run at 1024 due to screen size.
Thanks for your help
Spec in sig.
Ps only able to run at 1024 due to screen size.Thanks for your help
