So i've got my rig in my sig... but this is for use at my dads house... and I spend probably 3/4 of my time here. But i've also got an outdated computer at my mums.
The spec is nothing of any importance tbh, it's a 2.8GHz P4... an old MSI 865p or 875p, 80gb IDE HDD, 256mb ATI GPU (Not even sure which one as i'm at work) and an unbranded PSU.
Now, for about £100 or less if possible i'm looking at replacing the CPU and mobo with either a dual or quad core and a mobo that is obviously capable of taking PCI-E. I am happy to try a second hand CPU if it means I can get slightly faster for cheaper (usually the case) as with mobo, but if it will fit in the budget then I'd happily pick up brand new.
I'd also like to fit a GPU in there somewhere as I have 2x decent (ish) GPU's but they are both AGP and I'm guessing to get a slightly better mobo, I won't be able to get one with AGP.
I'd like the CPU to be capable of OCing if at all possible so I can squeeze a bit more out of it and cooling wise I'd just buy an Arctic Freezer if it fits.
It will be used mainly for WoW and the occasional 'other' game.
Any advice be appreciated.
