cpu, mobo temp and room temps
30 Aug 2003
at the moment my room temp is at 26.9
my mobo temp 35
my cpu temp 39 (idle)
is this all about right?
im not concerened about my temps but was wondering if i could lower it all (i like warm rooms)
all fan speeds are at lowest settings but put them up when gaming which keeps my cpu around 45 at load and my graphics card at around 65
Yeah they seem alright to me, are you using the stock cooler on your CPU, 39 idle is quite high, but this is probably due to your roasting room.
I agree 39c is quite high but I'm assuming it's to do with you running all your fans at low speed, seeing as at full speed your load temps are only 6c higher. Is this full load, i.e. what are you running to get this temp?
