cpu/mobo upgrade
9 Apr 2012
My current setup:
AMD Phenom II X4 965
ASUS M4A785TD-V EVO
Sapphire 280X Vapor-X
6GB RAM
I've got down to two options...
i7 4970k & Asus Maximus VII Ranger
http://www.overclockers.co.uk/showproduct.php?prodid=BU-013-AS
or i5 4670k with the same mobo.
With the bundle offer there's £60 difference so I'm thinking it would be worth it to get i7. Especially because I use 3ds max/maya etc.
So is the extra £60 worth it? Or any other options to look at?
http://www.overclockers.co.uk/showproduct.php?prodid=BU-014-AS&groupid=2833&catid=2836&subcat=2861
massive upgrade over what your running
What motherboard do you have right now and what are you looking to spend
ASUS M4A785TD-V EVO
I'll just spend whatever can be justified to be honest. I guess my limit would be £365 based on the original bundle I posted. I don't think I'd need to spend any more than that.
The reason I was more inclined to go with i7 is because of the benefits you gain through rendering in 3ds max/maya as this is painfully slow on my pc as you can imagine.
I quite like the networking and audio options that come on both the Asus Maximus VII Ranger and Gigabyte Z97X-Gaming 7 which seem to be missing from ASUS Z97-K although I'm not sure these make up for the price difference
ASUS M4A785TD-V EVO
The Maximus boards are fantastic, i am not a fan of gigabyte boards. they are good i just dont like them myself.
will you be gaming on the system and dose your budget include the cost of a new gfx card
I'm also a big fan of ASUS boards over other brands.
Yes, I will be gaming but I'm not looking to upgrade my gfx card anytime soon.
It probably would do but playing games on highest settings is something that doesn't bother me. I still only really play UT2004/CoD4 anyway.
The reason for i7 over i5 is rendering.
at the prices an i7 can be had it i dont see any reason to not get one if its right for you and it look like you know what you need so go for it. i would go with the asus board
So there is! Thanks for the info.
It says claim 30-60 days after purchase but the promotion ends on 03/10/14 so will I not be able to claim it then?
no what it means is.
30 Days after purchase is the earliest date you can submit cashback claim
60 days after purchase is the latest date you can submit cashback claim
the promotion ends on 03/10/14 for purchases
